2000 QuadMaster 500 has huge backfire/afterfire when turning off
By mehim
By buriedpast
By rjsummer
By hurnyak
What is the best way to remove the carb on a 2000 quadmaster 500? Does the gas tank need to come off first?
By middlebrookgt
