Hey guys new to the forum ..and having a little trouble with my kingquad ...recently changed my clutch and now I’m having the problem of my belt slipping ...took belt box off and found a ton of oil !!!! Any ideas what this could be ? Any help would be appreciated ..and I’m also new at fixing my own bike so plz bear with me
    • By quadnut20
      Just picked up a 2025 Yamaha Kodiak 700 fixing to do a EPI Clutch mod to it since I dropped bigger tires on it !! Air box , exhaust , and programmer next !
    • By jen
      Cannot find out why 12 vdc  4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.   When attempting to run  with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.  I can buy a rebuild kit ~$35 but WTH?
    • By captnunu
      I have a 2007 kingquad 450 fuel injection. I try to start it with the hand crank and almost flip over the quad. I have taken the hand crank off and cleaned it but this did not fix the problem. I believe there is a decompression valve that is supposed to engage when pulling it over by hand. How can I check this?
    • By ButchM
    • By Zrach
      I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
      This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
      Note: This modification compromises the factory “no-start” circuits.
      On some malfunctioning CDI units the internally damaged circuitry is only partial.
      Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
      The Modification
      See the second diagram attached below for the wiring specifics.
      The Result:
      The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
      ⚠️ IMPORTANT SAFETY WARNING ⚠️
      Please be aware that this modification compromises the factory safety "no-start" circuits.
      The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
      Faulty CDI Workaround.pdf
