07 Suzuki Vinson 500 Automatic Transmission problem grinds in high and low/ won't shift into park
By crankin
By jeffrocdx
By Baldwin007
I was wondering if anyone out there has a digital copy of an Owners Manual for a 2003 Suzuki 500 Vinson 4x4? I have a service manual, but no Owners Manual. I would like to know how to correctly operate/engage various features.
By harryjr
hello everybody my name is Harry jr and i recently picked up a 90's Yamaha moto4 225 i beleive and neede a starter was all he said ( i know right ) thats what they all say
anyway i picked up a starter and installed it and when it is crankling it sounds as if it is not turning over freely as i9f there was a one way bearing not worrking correctly so pulled with recoil and it pulled back so hard i ripped out of my hand so hard it actually hurt now i have pulled and kicked a lot of bikes and such but never felt anything quite like this you can hear it try and fire and kick back but still acts as though somthing holding it back does that make any sense to anybody is it flywheel key , or valves wauyout any help would be great i picked tow of these up for $100 and tring to fix so we can ride as a family thank you in advance.
By jordan_ATV
