It does sound like timing, does it blow gas out the carb or just smoke, put your hand over the carb inlet while turning it over you should feel suction on your hand as it approches the firing stroke then it will let go and you will feel it again, it you feel a weird pressure against your hand trying to blow it off the carb something is not right.
    • By Joeguy
    • By realpilot
    • By OldATVowner
    • By Dsluder
