Bought a 2nd hand 2017 polaris sportsman 450  with 12000 hours recently and have done a lot of maintenance including a new 18 amp battery
to assist faster starting. Having expected to find a 4 valve head i took the valve cover off and found a single ohc with its 2 buckets. At first dissapointed, i realized
this was a run forever engine, no visible wear noticeable and still running perfectly. The decompressor ball was missing in the camshaft, with the lever and spring
still in place. Since the motor starts at once every time i think its better to keep the camshaft as is . In my experience a decompressor is only needed for a manual starter.
I just had the same sort of issue with my 2017 450 HO and it lead to my cam breaking. The ball had fallen out of the hole and was rolling around on the head. I only have around 400 miles on mine. If I could I would get a cam without it.
59 minutes ago, mxracer13 said:
Shouldn't be a problem MX, Take the cam out,and enlarge the hole with a mini grinder so the ball comes out. The actuator can remain in place or remove the sprocket and get rid of it. A full size (18 amp ) battery can handle the compression easily. In my 50 years as a mechanic i've never seen such a brilliant cam lobe destroying device as in Polaris. Go for it
    • By Trent Finnessey
