No spark, continued
Go to solution Solved by ScottCarl,
So, on my 84 TRX200, I've replaced everything except the stator and regulator. New coil, cdi unit, (spark pickup tests good) new sparkplug. No spark. Ohm tested stator on the bench. Book said 0.1 - 1 ohm. I have 3 - 4 ohms. Bad?
Wiring had been boogered up when we got it. (Key switch bypass) Not sure if related but wiring diagram shows a blue and yellow wire from CDI to the spark pick-up (pulse generator) Not sure what was hooked up there, but CDI unit plug didn't look like a blue and yellow wire was EVER plugged in there. It has one now ;)
I had it running for a few seconds, and then it quit. Been searching for spark ever since.
Help. TIA, Scott!
I had unreliable spark on a honda cr250 dirtbike (i think the stator might be it but i'm not too sure) (sometimes the spark would be bright and then nothing for 2 kickstarts) very sporadic and dissapearing spark
  • Solution
I put a new (to me) stator in. Still nothing. Went so far as buying another wire harness. Still, nothing. Spark generator tests good, but it's the only thing I haven't replaced. I have a new one enroute.
You know the electrical wiring plugs/plug ins attached to all the dfferent rnadom bunch of wires (the ones i have seen look like a copper tube covered in soft bendy plastic plugs that are at the ends of the wires?
Maybe one of them has corrosion or a loose connection and things only work if the bike wiggled a certain way or something
Oh i forgot you typed that you ordered a new wiring harness. So that should means the wires should be in new condition so no corrosion / maybe one of them is loose but probably not // tomorrow i will hear the results from my dad about the cr250 honda dirtbike strange spark plug behavior and maybe it will be some sort of clue// it is stator/cdi box/ wiring harness sort of problem too
No, really. It's is the only thing left. 🤣😂🤣 New wiring harness, new CDI unit, new coil, new plug.
To be honest, it's a used item but intact. The one we replaced had splices on splices. It was a mess when we first got it
i had to take the day off work so i will find out the results on Tuesday about the Honda cr250 dirt bike //Coil/stator/wiring harness/ cdi box        the problem is sporadic spark plug behavior ( we turned off all the lights in the garage so it was very dark) he kicked the kick starter about six times and i observed the sparks from the spark plugs.
1st time - low ish medium spark
2nd time - no spark
3rd time - no spark
4rth time - very faint spark
5th time - big medium big bright spark
6th time - very faint spark
The customer guy gave my dad two different CDI boxes and some other stuff (we tried a whole bunch of things and cannot figure it out). We are guessing both CDI boxes are bad so the Honda cr250 owner guy tracked down a 3rd CDI box// the whole situation is confusing
So the guy ordered in 4 or 5 new replacement electrical parts. I think it is new CDI box, new coil, new stator, wiring harness and maybe something else too
( previously we tried everything and could not figure it out but then 'guess hypothesized that both CDI boxes the guy gave us were fucky)    //     We have no idea what is wrong (dad says maybe some switch inside of both of the CDI boxes the guy gave us is fucky)
I don't know the status of the weird spark plug behavior because my dad said something about the fly-wheel and he had to order in some special part in do do something with it.
    • By RGS
    • By Kawasakibayounospark
