Hi everone, got a funny thing going on, 1998 Suzuki King Quad  LTFX4WD , started it yesterday, fired right up idled fine, when throttled up it started dieseling and missing badly. Having replaced the coil package recently I checked all connections again, still ran poorly, for some unknown reason I switched ignition to the lighting position, fired her up and WTF, runs perfect? I'm thinking short but where, ignition switch? Any help much appreciated
Hi Steve. That, turning the lights on fixed the problem, normally points to a charge regulating problem..  First check is what voltage you have at the battery, then that it\s charging, then that it's regulating correctly.
    • By Fonne
      Hi
    • By jay41198
    • By mehim
