Hi All,
 I've been going through the manual trying to get the charging system on this old LTF230 to work properly,  and ran down sections 8-6 through 8-11 in the manual; http://www.crservice.dk/Suzuki%20ATV/LTF250/LT-F250_01E.pdf#G2.1000137
I checked the resistance of the generator coils, verified they are within range, checked the open-circuit AC voltage of the generator and found it to vary between about 24-60V on all three legs, and then replaced the regulator/rectifier.  When I tested the new regulator/rectifier, the tester probes give me the correct voltages doing the diode test.  However, when the engine is running and rectifier attached, it heats up and at an idle produces around 9VDC, but when I rev the engine it drops to around 1VDC and heats up, as most of the energy appears to dissipate as heat.  I am testing the DC output with only the 3 wires from the alternator connected up to the regulator unit.  Is this a bad regulator/rectifier, or do I need to connect the negative to chassis ground and positive to the battery terminal before I see something around 13V from the regulator?
I took off the cover and removed the stator coils, they are in perfect shape and this is not the issue.
Also, I have hooked the battery to the starter relay, when i click the starter relay closed the starter motor will turn when it is removed from the engine, but when installed it does not have sufficient force to turn the crankshaft of the engine but simply makes some noise and vibrates.    Should I replace the starter motor or take it apart to inspect the brushes? I'd like to get the charging system and starter motor to work; as I'm tired of cranking over the engine by hand.
Thanks in advance!
  • Solution
You need the battery in there to do any meaningful output tests. The regulator will get hot if it's trying to control an open circuit voltage. They work by shorting the excessive power to earth, but they are also designed in anticipation of about one to two amps(make and model) load always going into the battery.
The starters wear out brushes regularly. it's an easy fix. They sell new brushes, springs etc all on  new brush holder plate. cheap !
  • 5 weeks later...
That fixed it! 13+V once I had connected it to the battery.  It was overheating when it wasn't connected.  I had make a wiring harness from scratch using the new regulator, new starter relay, new starter, battery, key switch and handlebar switch.  Looks like it all works as expected.  May add lights and winch.  The starter clutch sounds godawful.
    • By RadRob
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By leecon
    • By KSIM
      View File CFMOTO CF500-6 CF625-3 (CF600-3) CF625-6 (CF600-6) service manual
      CF-MOTO cf625-3 и cf625-6-cf600-6 service manual
      Submitter KSIM Submitted 03/19/2025 Category Other Brands UTV
