I bought a used 2019 ds 70 a couple weeks ago for my son. If I had to guess it has under a 100 miles. It still has the nubs on the tires.
It starts right up on the first crank. After he rides for a couple minutes it will stall when he stops. If he doesn't stop it won't stall but as soon as he stops it shuts off. I can get it started but it take about 3 minutes of cranking the engine before it will fire back up. Then again after a couple minutes of riding it will stall as soon as he stops. Any recommendations?
Bump for some help.
First thing would be to check the idle mixture is set right.
If it's a two-stroke, I'd check the oil/fuel mixture is right, and what I'm always going to use in future, then I'd adjust the idle mixture screw.
If it doesn't respond to the adjustment, or if it  doesn't cure the problem, then we can look a bit deeper.
Edited by Mech
Hi, I have a Suzuki King Quad 300 and had same issue. Hadn’t been started for a couple of months. Thought it might be the fuel had gone off so drained and cleaned the tank filled with fresh fuel but was still the same. Pulled the car by apart and found the primary/idle jet was blocked cleaned that and the carby and other jests and runs like a charm again.
Bump for some help.
I had a little tine over the weekend to look a this.  I adjust the idle just slightly and that seemed to fix the issue.  I'm going to have my son ride it a little longer today just to make sure but I think that did the trick.
    • By cruteg8
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
