I have a 2007 400 Kodiak. The air box was full of gas (3") as well as the oil system (gushed out of the filler plug). What am I looking at here?
Fuel  valve left on and the carb flooded  either from a  bad seat or stuck float.  You'll need to  completely  drain the  crank case  and refill with fresh oil,   drain and clean the air box and find out why the carb flooded.
Pull the spark plug and make sure the cylinder is not also  flooded.
Edited by davefrombc
Thanks Dave, very quick response! I am in the process of getting a new carb bowl as the bowl drain valve wont seal. Maybe a new carb is in order.
The part you need to clean is the needle and seat that's connected to the float. The float needs checking too. Shake it to check it's not fill of fuel.
You should download the manual and read the section on carbies before you begin.
    • By Eisenmatt17803
      Good Morning!
      Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
      Thanks in advance.
    • By quadnut20
      Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into  ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
    • By vlxerdon
      Don
    • By shorty
      Looks like this is the right place to introduce myself. First time ATV owner.
      Gary
    • By 95kingQuad
      As the title says I am on the search for a used OEM 1995 King Quad Carb. I believe it says Mikuni on the side. If you could even help me find info on which carb it is exactly that would be helpful too, or motorcycles/other quads that use the same carb. Thanks!
