2007 Kodiak 400, case and air box full of fuel.
ESOX
Fuel  valve left on and the carb flooded  either from a  bad seat or stuck float.  You'll need to  completely  drain the  crank case  and refill with fresh oil,   drain and clean the air box and find out why the carb flooded.
Pull the spark plug and make sure the cylinder is not also  flooded.
Edited by davefrombc
    • By JohnnyB
      Greetings,
    • By mga
    • By Slitzer
      How often do you change oil in front/rear diffrentials and gearbox?
    • By jatho
    • By jatho
