1985 honda 250 four trax will not shift into 1st ? also would like to install a new fuel gauge that I can read if anyone knows where I can get one.   thanks
Have you read the owners manual.. some of the old models had a lock, you had to push a button or lever to get them into reverse and superlow,,
It might be you aren't doing it right, or the lock is malfunctioning..  The owner manual might point you in the right direction.
And the shift in N-SL-1-2-3-4- Yes? And N-R ?
So is it first or superlow it won't engage ? And does the lever move without doing anything, or does it come up solid against something so it won't shift ?
    • By toe420
    • By TomJulio
    • By NewToAtvs
      Hello everyone, I just recently purchased an ATV for 60$ and after some research I have come to the conclusion that it is an 85 LT230. The previous owner says that it is seized and well now I have taken it apart and want to know what I should do to get it running.
    • By jeffrocdx
