Just installed the front and rear rack extenders for mine.
Kinda thought the rear was a bit lacking in verasatility.
Heres the end result of stage one modification, as well as the front rack and "tool" holders installed.
The front bag doubles as a waist pack "glove box" and the rear bags are actually a 2 piece hunting pack that hold basic load management and extraction gear.
They all dismount fairly quickly and can be repurposed for other uses.
I end up riding solo a lot and try to keep on hand what I might need to get myself home just in case.
The upper rail on both ends is an OEM add on. The lower rail on the rear I welded in myself. makes for much better mounting options for gear as it overhangs the basic rack by about five inches.
I might add some light gauge expanded metal later.
I could have built them completely myself, but I couldn't quite make out "where" they attached and the material at the moment would have cost almost as much as buying them.
the rails do really make the rack much more usable, too.
adding the lower rail on the back was a definite positive . . its worked out really well.
Most of it is fairly "quick change" and IM working on a few more add ons to make the racks even more versatile.
    • By TomJulio
    • By Ant-Knee
      I am trying to rebuild an engine for a '97 Kawasaki Prairie that I recently picked up. There is one head bold that just won't let go. Nothing I do seems to make a difference. I have been putting penetrating lube on it for two days straight and I am afraid it is going to break on me. What is your best advice for getting the sucker out? I have tried a rechargeable impact, a pneumatic impact and penetrating lube.
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By wjmedic
      right front hub again
