1998 Suzuki Quadrunner LT-F250 Smokes When Riding
Go to solution Solved by Mech,
My 1998 Suzuki Quadrunner starts well and idles steady with no smoke...until ridden.  Here are SEVEN short videos showing the problem.  Please watch in sequence and help me diagnose the problem and develop next steps to repair it.  Videos may be in following posts.  Thanks, in advance, for your words of wisdom.
It would appear to be the rings are worn, but before ripping it apart I'd check the engine breather system. First thing is check if the crankcase is pressurinsing. Idle it for a few minutes and then take the filler cap off and see if it puffs out air as it comes off. Put the cap on and run it or take it foe a ride and then with the motor stopped undo the filler and check for pressure. It's common to have a very small amount of pressure in there, but it shouldn't hiss or push on the cap at all as you take it off. With the cap off and the warm engine idling, check to see if it's puffing much air and oil out..  A bit of oil splashing is normal. There is a restriction in the breather that can block and cause either excessive pressure while it's running or even, if it's bad, residual pressure in the crankcase.
If the breather is clean, and if in doubt you should clean it, including the restriction that will be in the breather pipe somewhere I think. The restriction is sometimes under or in the air box, then, give the motor a few repeated revs. You want to open the throttle much slower than you were in those videos, but let the revs build to about the revs in the video, then as soon as it's up to revs close the throttle right off suddenly, when it gets near idle revs, but without letting it idle, give it a bit of throttle again till the revs build to the video revs. Keep doing that repeatedly and if you get the throttle opening speed and amount right, and the revs it goes to right, it will start smoking if it's the rings, and the more you do it, the worse the smoke will get. Try different amounts of throttle opening speed and amount, and revs, at some point it will start smoking bad if it's the rings. The revs in the video are the highest you want to go to, probably a little  less will work better. I've bought cars for people cheap by showing the owner how much it smokes.. haha..
When you are doing that rev test, don't let it get to an idle, and don't hold it at the revs either. The motor has to be constantly either accelerating or decelerating. From near idle speed, up to revs and back down again should take about.. err.. one to one and a half seconds..
Only give it light throttle, but snap the throttle shut. At the right combination it will start smoking.. Find the right combination and then stick to that for thirty seconds and it will get worse and worse.
I was NOT able to get it to smoke by manipulating the throttle as described.  This is the result after a short ride.  Also, when I remove the filler cap with it idling, there is enough pressure to lift the cap at the last thread...no hissing or pressure buildup.  With the cap OFF, engine speed slows slightly and exhaust comes out the filler cap just like the exhaust pipe.  The breather filter is saturated with oil and there is oil standing in the housing.  Sound like it needs rings?
Sounds like it needs the breather cleaned out and checking..
There' a restrictor in most of them, and, running up under the gear shift cover there is a breather pipe that can get squashed somehow..  Can't remember exactly but I've found them clamped down under the shift or the covers or something..
  • Solution
You were holding the revs up too long...  Keep gently cycling it always having the motor either accelerating lightly or decelerating sharply..  And use less throttle..  I bet I could fill your yard with smoke out of that thing..
I think you will find the oil rings are not doing their job.. Clean the breathers first though.. make sure you can blow through all the hoses except for the one with a restriction.. that should be harder to blow through but it should flow a small amount consistently. If you find a blocked breather, after clearing it, try riding it so it has long runs of steady, heavy load, without any sudden or hard acceleration and only gentle deceleration. Find a hill, use higher gears wherever possible, and don't let it rev away under light loads, change up as soon as possible..  Sometimes with a blocked breather the oil that gets blown up gets under the rings and they start floating on it.. If we can put a steady compression on it more than not, the rings slowly scrape the oil away and the rings reseat metal to metal.
You might get lucky.
Edited by Mech
    • By jay41198
    • By logray
      Hi all,
    • By Yamahahahaha
    • By LMI
    • By kevinohio
