Recently purchased an aftermarket fuel pump was defective, right out of the box would not pump any fuel. The old one worked fine. It was just leaking fuel. They sent me a replacement free only to find out that one didn’t work either after several hours of troubleshooting replacing fuel lines, checking fuel petcock only to discover that the small spring in the fuel pump was too tall, not allowing the diaphragm to pulsate the spring, measured 9/16 of an inch tall by placing it in a vice and shutting it down to half inch and reinstalling it back in the pump. it worked perfect this might help someone with the same issue in the future .
Sounds silly, but how exactly do these pumps work? I’ve got one in my LT300 that’s bad. It won’t delivery any fuel to the carb but I can push air through the lines, and I can blow bubbles into the tank from the fuel pump as well so I know it’s the pump that’s not working. Is there a better way to test it? I don’t know enough about it to say yay or nay. Thanks!
After digging in a bit.
realize that these are all controlled by vacuum created by the engine cranking. My pump still won’t pump fuel but I know I can get fuel from the tank. I ended up ordering a new fuel pump to test out and see if that immediately fixes the issue.
If it runs ok when the bowl is full then you need to figure why the bowl isn't staying full..
When the tank is full the fuel will/should flow out the carbs fuel hose if you pull it off.. You should check that happens first.
If there is fuel getting to the carb then use the drain bung to check it's flowing through the float needle and into the carb fast enough.
If there was no fuel to the carb then check for restrictions somewhere, or vacuum in the tank. That new pump might restrict the fuel when it's not getting vacuum. The tank vent could be blocked.
To test the fuel pump you lay the fuel hose to the carb into a bottle. Lay it on it's side with the hose laying flat. If the hose is dangling down you won't see the fuel pumping out properly. Then suck hard two or three times on the vacuum hose going to the pump, and then let the vacuum off suddenly. You should see a single slug of fuel come out of the fuel hose. The slug should be full diameter of the hose and about ten mills long. If that works then your pump is ok and will work if it's getting good pulsating vacuuum.
To test the vacuum you reattach the vacuum hose and start the motor and let it idle. It should pump fuel out of the fuel hose into the bottle at full diameter of the hose and slugs about eight mills long. If that works then the pump is working and it should start and idle at east.
Then you need to check the vacuum is still strong enough when the motor is under load. To check that you leave it all as is but sit on the bike, put the brakes on hard, engage first gear and open the throttle until the motor starts straining against the centrifugal clutch. As the motor starts to labour the pump will likely slow down it's delivery of fuel, but it should keep pumping some. If it stops pumping then you have weak vacuum or a malfunctioning pump.
The vacuum has to be strong, and pulsating when it gets to the pump. If the vacuum hose has been swapped with some soft thin walled stuff the pulsations can get lost as they suck the vacuum hose flat and then let it out again. Low vacuum can be caused by low compression, tight valves, or air leaks. Low vacuum at high revs can be caused by a blocked exhaust.
Oops. That was for someone else so the first few lines are not too relevant.
    • By DPDISXR4Ti
      Thanks...
    • By jwh
    • By GatorHunter
      Thank you, and enjoy
      GH
      1985 Scrambler
      1985 Trail Boss
      1986 Scrambler
      1986 Trail Boss
      1987 Trail Boss
      1987 Trail Boss 4X4
      1987 Cyclone
      1988 Trail Boss 2X4
      1988 Trail Boss 4X4
      1988 Trail Boss 250 R/ES
      1989 Trail Boss
      1989 Trail Boss 2X4
      1989 Trail Boss 4X4
      1989 Big Boss 4X6
      1990 Trail Blazer
      1990 Trail Boss 250
      1990 Trail Boss 2X4
      1990 Trail Boss 2X4 350L
      1990 Trail Boss 4X4
      1990 Trail Boss 4X4 350L
      1990 Big Boss 4X6
      1991 Trail Blazer
      1991 Trail Boss 250
      1991 Trail Boss 2X4
      1991 Trail Boss 2X4 350L
      1991 Trail Boss 4X4
      1991 Trail Boss 4X4 350L
      1991 Big Boss 4X6
      1991 Big Boss 6X6
      1992 Trail Blazer
      1992 Trail Boss 250
      1992 Trail Boss 2X4
      1992 Trail Boss 2X4 350L
      1992 Trail Boss 4X4
      1992 Trail Boss 4X4 350L
      1992 Big Boss 4X6
      1992 Big Boss 6X6
      1993 250 2X4
      1993 350 2X4
      1993 250 4X4
      1993 350 4X4
      1993 250 6X6
      1993 350 6X6
      1993 Trail Boss
      1993 Trail Blazer
      1993 Sportsman
      1994 300 2X4
      1994 400 2X4
      1994 300 4X4
      1994 400 4X4
      1994 300 6X6
      1994 400 6X6
      1994 Trail Boss 2W
      1994 Trail Blazer 2W
      1994 Sportsman 4X4
      1994 Sport
      1995 300 2X4
      1995 400 2X4
      1995 300 4X4
      1995 400 6X6
      1995 Trail Boss
      1995 Trail Blazer
      1995 Sportsman 4X4
      1995 Sport
      1995 Xplorer 4X4
      1995 Scrambler
      1995 Magnum 2x4
      1995 Madnum 4X4
      1996 Trail Blazer
      1996 Trail Boss
      1996 Xplorer 300
      1996 Xpress 300
      1996 Xplorer 400
      1996 Xpress 400
      1996 Sport
      1996 Scrambler 4X4
      1996 Sportsman 4X4
      1996 Sportsman 500
      1996 400 6X6
      1996 Magnum 2X4
      1996 Magnum 4X4
      1996 Magnum 6X6
      1997 Trail Blazer
      1997 Trail Boss
      1997 Xplorer 300
      1997 Xpress 300
      1997 Xplorer 400
      1997 Xpress 400
      1997 Xplorer 500
      1997 Sport 400
      1997 Scrambler 4X4
      1997 Scrambler 500
      1997 Sportsman 4X4
      1997 Sportsman 500
      1997 400 6X6
      1997 Magnum 2X4
      1997 Magnum 4X4
      1997 Magnum 6X6
      1998 Trail Blazer
      1998 Trail Boss
      1998 Xplorer 300
      1998 Xpress 300
      1998 Sport 400
      1998 Scrambler 400
      1998 Scrambler 500
      1998 Xplorer 400
      1998 Magnum 2X4
      1998 Magnum 4X4
      1998 Sportsman 500
      1998 Big Boss 500 6X6
      1996 Sportsman 400
      1996 Sportsman 500
      1996 Xplorer 500 4X4
      1997 Sportsman 400
      1997 Sportsman 500
      1997 Xplorer 500 4X4
      1998 Sportsman 400
      1998 Sportsman 500
      1998 Xplorer 500 4X4
      1999 Sportsman 400
      1999 Sportsman 500
      1999 Xplorer 500 4X4
      2000 Sportsman 400
      2000 Sportsman 500
      2000 Xplorer 500 4X4
      2001 Sportsman 400
      2001 Sportsman 500
      2001 Xplorer 500 4X4
      2002 Sportsman 400
      2002 Sportsman 500
      2002 Xplorer 500 4X4
      2003 Sportsman 400
      2003 Sportsman 500
      2003 Xplorer 500 4X4
      A01CH50AD
      A01CH50AA
      A01CH50AB
      A01CH50AE
      A01CH50AK
      A01CH50AF
      A01CH50AJ
      A01CH50EB
      A02CL50AA
      A02CL50DA
      A02CH50AA
      A02CH50AB
      A02CH50AE
      A02CH50AK
      A02CH50AC
      A02CH50AD
      A02CH50AJ
      A02CH50AL
      A02CH50AM
      A02CH50AN
      A02CH50FA
      A02CH50AAEB
      A02CH68AA
      A02CH68AB
      A02CH68AC
      A02CH68CA
      A02CH68CB
      A03CL50AA
      A03CH42AA
      A03CH42AB
      A03CH42AC
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03GJ50AA
      A03GJ50AB
      A04CL50AA
      A04CH42AA
      A04CH42AE
      A04CH42AG
      A04CH42AQ
      A04CH42AT
      A04CH42AV
      A04CH42AS
      A04CH42AR
      A04CH50AA
      A04CH50AC
      A04CH50AE
      A04CH50AG
      A04CH50AO
      A04CH50AQ
      A04CH50AR
      A04CH50AS
      A04CH50AT
      A04CH50AV
      A04CH50AW
      A04CH59AF
      A04CH59AH
      A04CH59AJ
      A04CH59AT
      A04CH59AV
      A04CH59AK
      A04CH59AL
      A04CH59AN
      A04CH59AW
      A04CH68AC
      A04CH68AF
      A04CH68AH
      A04CH68AJ
      A04CH68AT
      A04CH68AV
      A04CH68AK
      A04CH68AL
      A04CH68AN
      A04CH68AO
      A04CH68MB
      2004 Ranger 2X4 Parts Manual
      A04RB42AA
      2004 Ranger 4X4 Parts Manual
      A04RD50AA
      2004 Ranger 6X6 Parts Manual
      A04RF50AA
      A05CL50AA
      A05MH42AB
      A05MH42AG
      A05MH42AH
      A05MH50AB
      A05MH50AC
      A05MH50AG
      A05MH50AH
      A05MH50FB
      A05MH59AK
      A05MH59AN
      A05MH68AK
      A05MH68AN
      A05MH68AC
      A05MH68AS
      A05MH68AU
      A05MH68AW
      A05MH76AC
      A05MH76AU
      A05MH76AW
      A05MH68AP
      A07MH68MA
      R07RF68AD
      R07RF68AF
      R08RF68AD
      R08RF68AF
      2009 Outlaw 90 service manual
      Other Stuff
      Download Manuals HERE
      Some ATV manuals available in the downloads section at https://www.quadcrazy.com/files/
      Find them on on:
