2002 Yamaha Banshee 350
By hengstserepair
Nuetral: Runs as expected
Lorne
By Rockbottom
By Mister907
By jeffinotown
By HeWasRidinDirty
The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
