1993-1999 Yamaha YFM400FW Kodiak Service Manual w/Supplement
By HSTAR
By ResQ91
Hi guys
battery and connections good
By STLJ
Gday all,
Been trying a couple different ways now to download a manual. Not sure what I am doing wrong but could someone walk me thru it?
I go to DL page and click on link
get a pop up for a PDfixer or something
close that and then hit download button and no go
tells me I have reached my limit but I have never DL anything ever.
By McG75
Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds. It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
By McG75
