    • By vlxerdon
      Don
    • By Louznmemind
    • By Louznmemind
      Can someone please tell me the fill point on the drive axle? '07 Grizzly 350, straight rear drive, not independent. Thanks
      My 2004 Yamaha Grizzly 660 seat is a mess, torn up, cracked, and I have been duct taping it for a while.  I bought new vinyl for $35 and need to do it one day. A new seat used to be well over $250 but now its under $100 so I couldn't resist. I got it on ebay with a 10% off coupon for $85.05 plus tax. https://www.ebay.com/itm/146040022154
      In case anyone is looking for a new seat for their Yamaha Grizzly 😁
      I saw it on Amazon as well for under $100
    • By shorty
      Looks like this is the right place to introduce myself. First time ATV owner.
      Gary
