I think i would, while you are in there, it would be good to go ahead and replace it, it is approaching 20 yrs old. I  think aftermarket bearings are fine i havent had any problems with them, just make sure you pack them really good with grease upon installation.
That kit is for both sides and I only see housing seals in the kit. I'm not sure what small seal you are meaning. The O ring I'm mentioning is to stop water getting under the hub nut and making it's way along the cv shaft and into the bearing housing. Apart from keeping water out of the housing, it stops the shaft rusting into the hub.
It says the bearings are OEM which stands for original equipment manufacturer, so they should be from the honda parts department. They aren't in honda parts packaging though so I'd be a bit dubious about that. Even more suspect is that the enlarged pictures of the bearings don't seem to have any bearing number stamped into them as I'd suspect. Good makes, like timken, skf, nsk, koyo, always have the bearing number stamped into one edge. Bearings do vary a lot and you can buy bearings that range in price by a ratio of three to one, and they have the quality to match.
Good eye Mech, i had to look for it. It does say OEM but from reading the reviews i dont think they are, not bad reviews, just the way some were worded, like they were surprized they fit perfectly.
Anybody that isn't willing to put their name to their work or product has to be suspect..  haha.
All the reputable bearings have the makers name on the races.
I was fitting honda ct90 front brakes to wheelbarrows years ago and decided I'd go with cheap bearings, $8.00 instead of $24.00, and I was surprised how crappy the cheap ones were.
    • By WeeBee
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
