I have a rancher 420 TM that since i bought it has a cold hard shift problem beyond a doubt clutch is not releasing by shift lever. After it gets good and hot it shifts ok. Tried preloading adjustment screw clutch releases and shifts smooth but slips. Have had the clutch out and apart twice for inspection and didnt see anything wrong. Any tips will be appreciated. I've ran out of things to try instead of throwing new parts at it.
  • 6 months later...
    • By Cj Winds
    • By logray
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
    • By jeffrocdx
    • By quadnut20
