Well tell us what sort of transmission it has then.. Two speed hand shift or five speed foot shift.
If the engine is running will it shift to neutral ? Will it start in gear if you apply the front brake ?
And have you been rocking the bike back and forwards as you try to get it out of gear ?
When you take the side cover next to the shifter you should see stator in the case, on the engine the flywheel and pickup coil along with the shifter mechanism, hopefully its in better shape than mine was, although i wasnt having shifter problems. It had just sat with water in it for a while.
Check to make sure the shift drum is rotating freely and the spring is attached and doing its job.
    • By Jdeaton011989
    • By tflack500tbx
      Background,
      Any Ideas?
    • By jeffrocdx
    • By wilmpie
      hi everybody
      thanx in advance
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
