    • By pastorjeep
      Need a little help fixing a no spark issue. 2002 BT with the 2 wire ignition switch. I have 4 stators and 2 CDI's and 3 coils to test. The new stator reads 218 ohm, and .2 ohm, the one that came out of it reads 50K and .2, the other is 132 and .2. All of the coils are 0.00 ohm, and there is no way to test the CDI that I know. I have also confirmed the replacement stator pins match the factory locations. I did try to test milli-volts at the coil to see if it was getting any signal from the CDI but nope. IDEAS?
    • By MOORETARHEELS
      I have a 2006 LT 80 done a top end rebuild and only have 80psi.  Any suggestions on what it could be.
    • By xxjeanxx30
      so i have bought a quad (1985 suzuki LT250E) and the quad had the wrong spark plug and was not tight enough I now have dirty tread and a compression leak what would be my best option try to force the spark plug or take a tap and clean the tread ?
    • By DZL1
      Thanks in advance.
    • By lester
      I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
