How do I test the neutral switch on my 2000 Yamaha Big Bear 400 4X4?
Go to solution Solved by lester,
I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
From the video I saw of another model,  the  neutral  switch is located low on the left side of the transmission.  Disconnect it and use a test meter to see if it shows open and ground when you  shift in and out of neutral.  If  it tests ok, then  test  the wire to  it for power  with the ignition on  and shifting in and out of neutral.
To  test to see if the starter itself is ok  you can run a wire directly from  battery  positive and touch it to the positive terminal  on the starter.  If it is ok,   also  check the starter relay.
Okay, so I have disconnected the neutral switch and can't get it to read as you say, BUT, I have also tried bypassing it by placing a jumper wire between the two wires on the plugin that plugs in to the neutral switch and it does nothing different.
I jumped a heavy gage wire from positive on the battery to the starter and it cranks, the problem is, now I have absolutely no power when I turn the key on. I have checked all of the fuses, and they appear to be good, is there an in-line fuse somewhere?
More suggestions?
Yamaha change their wiring often. I think we need to get the RIGHT service manual and wiring diagram for that bike.
Here are two that both claim to be your year and BB. Check how many wires the cdi has and let me know and I'll see how many wiring diagrams I can find with the right cdi.. Or, if you have the YMF400 suffix it would help.
00-05bigbear-kodiak400.pdf 2000-2001BB400.pdf
For the lack of power now, after jumping the starter, check the earth contacts and the battery cable to terminals connections, and battery to cable.
If that is the right diagram then you should check that relay 8 has power to it on the R/W wires, and that the Y/B wire is getting shorted to earth when the brake lights or the neutral lights are on. If both those things are right, then check that the L/W wire on the start relay is 12v, and that it's getting 12v to the start solenoid 6. If the 12v is getting to the L/W wire at the solenoid, check that 12v is getting to the L/B wire on the start button, and that that 12v drops to zero volts when you push the start button.
Yeah I always thought a front brake did it on most bikes, but in that diagram I noticed it says it's the back brake switch, and I notice that bike has no brake lights shown in the diagram..  So perhaps this is a different model than the diagram..
Check the wiring diagrams against what's actually fitted to the bike Lester. They wire their relays etc in several different ways, and there are several different CDI, stators, pickup coils. The wiring diagrams show the plastic plug shapes and colours and pin locations, all of which they change from year to year and/or market to market. Sometimes they change things half way through a year. The bike always needs checking against the wiring diagram no matter how sure we are about the model and suffix etc.
I'm not so sure that the CDI would have anything to do with it at this point? It has absolutely no power now, no headlights, no nothing. It's a dead puppy. I'm wondering about the ignition switch, or the kill switch, and if these might be the problems how would I test them? All of the fuses are good unless there are some inline fuses that I don't know about.
00-05bigbear-kodiak400.pdf 58.7 kB · 1 download 2000-2001BB400.pdf 42.05 kB · 1 download
It matches the 2000-2001BB. There is no power going to lhe plug.
Which plug ?
I've been giving advice based on that manual, so if you go back and read what and where I say to test for power it should lead us straight to the problem if there is only one problem. If you report back then I can have another look in the diagrams and try to figure if the test is conclusive, whether there could be multiple faults, whether we have the wrong diagram or different parts.
You should use a test light to trace and check for power, a meter doesn't show up bad connections as clearly as the light does.
If you are testing things and reporting back, it helps if you say exactly what you did and found, and to which coloured wires, and at which point in the diagram.
Ok, if you don't have a test light, which puts a small load on the circuit when it's lit up, then you need to get familiar with the concept of a "voltage drop test". The gauge will detect 12v even if there is some dirty connection only letting enough power through to make an led go, or the light in your meter light up, but it doesn't mean there is going to be enough power getting through to run anything that needs real power. You will be able to read up on google about voltage drop tests.
Or, improvise a test light using a tail-light and a couple of wires. The light won't light up bright of there's a bad connection you are testing.
You have your meter set on the continuity mode, that will tell you if you have a broken wire, put leads on each end of wire it should beep. It wont show voltage. If you use a test light or set meter to DC volts, one lead to wire and one lead to ground, if light lights up you have voltage, and meter will show you how much voltage.
If you are saying that the engine is cranking without the neutral light or the brakes being on, then there is still something not right with the wiring..
That Sb wire that goes to the cdi and neutral switch has to be at earth potential for the cdi to allow the start circuit to work, that wire isn't at earth potential normally because the neutral bulb is letting power through which keeps the Sb wire showing 12v at the neutral switch and the cdi. It's only when the neutral switch shorts the Sb wire to earth, causing the light to come on and the Sb wire to show zero voltage at the cdi that the cdi lets the starter circuit to work.
Are you really sure that wiring diagram for the 2000-2001BB400 is the right one ? Are the plastic plugs exactly the same shapes and colours, Look at the stator plug and the regulator plug. Yamaha make a lot of changes and they change plugs shape and colours so we won't and can't muddle them up. The two diagrams I posted won't be the only options, and there will be other options that still use that cdi unit and plugs, but have differences elsewhere..  You really need to be completely sure you have the right model manual or you will get lead down the wrong path..
I replaced the starter solenoid and both relays in the battery compartment, as well as the engine start / run / off headlight switch. Yes, I am pressing the hand brake in order to crank the engine in neutral. Yes, as soon as I start to crank the engine the neutral light comes on, just not before I start cranking. Yes, the plugs are exactly the same shapes and colors as the wiring diagram for the 2000-2001BB400. The pedal is just barely off with the light, just a slight movement will light up the light, that is why I am asking if there is an adjustment.
Ok. I don't think there will be any adjustment on the switch. They generally have two bolts going through two round holes. You might get a tiny bit of adjustment by virtue of the holes being a bit loose around the bolts, but it won't be much.
The oil temp light is meant to come on when you press the start button..  I don't think there's any reason the neutral light would come on because of that, but it might be worth investigating..
If you don't use the brake, and push the start button, the starter doesn't work, and the neutral light doesn't light up.. right ?
And are you sure the ignition switch is identical in operation to the old one ? They have a few different ones of those.
The relays, they are both identical huh ? And neither of them have a built in diode on the trigger winding ? I've been searching other wiring diagrams and I'm finding other ones that say they do that bike, but they are all different..  haha.
    • By justenmiller09
      I just rode my klf 300 all day yesterday, and today when i went to unload it it would not start. When i took the plug out to check for spark it only produced a very faint weak looking spark and it was not consistant with rolling over, is this from a bad ignition coil or could it just be a loose conection somewhere?
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By JGou
      Have an axis 500 bought from Lowes.. Have had to adjust the shift linkage  1/2 doz times in the last year.. Now the UTV is stuck in neutral.. Seems to shift ok through gears but neutral light never changes, and wont move at all when running.
      Only have 13 miles on this 4x4 and have had no other problems... Any help would be greatly appreciated.. Thx,  Jay
    • By Charlesbrown
      I was given a 07 big bear 400 with all the options. The prior owner ran it through water and it started smoking  so he took the head off and gave up. I have  a bunch of parts in boxes and did a quick inventory.  I need a jug, piston, rings etc and thinking it’s better to buy a complete top end. Does anyone have a recommended site to buy parts? I plan to go oem, no china junk but if there are quality aftermarket manufacturers I’ll do an upgrade.
    • By USRaider
      Hello all!
      Kept indoors but hasn't been run in 5 years.  We're not trying the engine until the gas is replaced, and the tires are reinflated. But the previous owner said their only issue was stalling when shifting to reverse without giving some throttle.
      I'm optimistic!  See y'all around!
