Regards
  • Solution
I'd suspect that "auto" is really a variable ratio/diameter set of pulleys and a belt. One of the pulleys will either be moving apart  to the shrink the effective pulley diameter, or, not separating when it is meant to be separating, and so causing the high revs and no top speed.
The struggling up hill might correct itself if you fix the pulley problem. Does the engine seem to have full power when it accelerates away from a standstill, or perhaps at mid speed it might perhaps to have full power ? If it seems to have full power at some speeds (the speeds the ratio it's stuck in suits), and if it isn't actually missing uphill, then I'd concentrat5e on getting the belt drive cured.
No it seems to pull away slowly than I would suspect also when it is struggling uphill I can release the throttle almost half way before the speed drops anymore ,
Sorry for late reply only just found your message
Paul
It sounds like the variable ratio belt drive system is playing up. You aren't mentioning missing or backfiring or cutting out or anything that suggests the engine isn't running fine, and those symptoms could be caused by the bike being stuck in a high ratio.. I'd look there first..
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By oztrax
      MAX 4 6X6 2008
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
