Another electrical problem, really??
Go to solution Solved by jen,
  • Solution
Multi pin connectors are usually suspect when you see  amps when unit is off...0.05 +-amps probably tolerable. Pulling fuses to reduce /eliminate current is an easy check.   Howeve,  Multi pin connectors will short out one pin to another and cause bat drain
BTW Tie Wraps on high VDC ignition leads are bad.  Many times guys will 'hog down' on tie wraps pulling the wire tight to metal (its grounded) housing.
  • Like 3
On industrial controls high voltage igniter wires laying pressed tight to metal  would cause control relay chatter on 120 vac circuits and play hell with low voltage  circuits  and frequency controllers.
You got to love it   ...it's like a murder mystery!
BTW I will mention it however, I am sure you guys know this but others may not. Do not use water-soluble flux when soldering cu wires.  Water-soluble flux will corrode the wires to dust.
And while I am venting on pet peeves....When trouble shooting one of the first things is "Tug And Pull "  No I am not talking about my hair. I've been around enough construction sites  to know how men's minds function.....LOL but tug  pull wire terminations.
Next look for unstripped wires at terminals. when the plastic is under the terminal  you will get no connectivity or worse yet intermittent connectivity.  Screw terminals for landing wires is the best (Point to point wiring).  I absolutely hate "Punch down Terminal blocks".  ( The wire is unstripped and placed over 'V' block and then punched into the V...😡
    • By realpilot
    • By jay41198
    • By 88bigbear
    • By cfherrman
