Ok gwbarm says tank is plastic and maxbeg says no rust inside, great but I still would drain that .3 gallon of old gas out of there. It's very easy, why keep that old crap in there?
Yes but there is still crud inside definately needs to be drained and cleaned out dish soap and water or simple green or whatever you have. Petcock needs to be taken apart and cleaned i usually put them in ultrasonic cleaner to vibrate corrosion off the metal surfaces, seals maybe ok if not broken you can soak them in brake fluid to rejuvenate .
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
