Rotate the engine to top dead center on the compression stroke remove the cam gear cover make sure the marks are straight across find the T mark on the flywheel make sure it is lined with the pointer if everything lines up you are in time. They very rarely jump time but its possible. A sservice manual would better explain it.
    • By cfherrman
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
