Our Poems
By middlebrookgt
By remnar
New member here,
I have searched here and other places and have not found an answer to my problem. As the title says I have a 2014 420 Rancher that recently started having an issue were the revs before the clutch engages.
I have checked the oil level (per the service manual) and replace the Valvoline ATV 10w40(less than 5 hours) with 10W30 GN4 for good measure. I have used the "pin" method to pull a DTC. I shows a 8-1 which is a TPS error. This makes some sense, as if the computer doesn't read throttle position correctly, it could have this symptom. I have checked the source voltage, and tested the TPS off the quad with a Fluke and a power supply at 5v. It is smooth and does not seem to be a bad sensor. I am confused by the DTC, because the PS light blinks the code, not the check engine light. However, there are no PS codes of that value. This condition appeared after a couple days of driving in the cold (~32°) and driving though some water/bogs.
A couple questions. First has anyone seen this issue, and do you have any suggestions? I have followed the troubleshoot right up to the point of replacing the ECU, which I don't seem to have one on the shelf :)
Second, anyone used a OBDII reader with an a 4pin adapter to pull codes? If so, what system do you use?
Beyond the rev issue, the quad runs and starts perfectly and when it decides, the clutch grabs tight (no slipping)
By loudsubz
Looking at a project rancher/foreman
1. I saw one today in person that is an 2008. It is having an issue where it will die after running for a little bit. At first I thought it was only when you shifted into gear but I left it in N and eventually it died out as if it was being starved of fuel. When you startd it after it started right back up though?
2. The unit has a tick sound (metalic). It's definitely there as I have a 2021 machine and don't have that tick. It seemed to mellow out a bit after it warmed up. The owner said hew top end was done awhile back, could it be a valve adjustment or would this mean something more?
3. The steering column was welded near the bottom where it connects into the knuckle part at the bottom. It almost looks like it snapped at one point and they welded it back together?
Just trying to decipher if these issues sound like they can be worked out fairly easily or if this is a basket case
By Gary Skriba
just got a 99 Kawasaki bayou replace the coil because the spark was very weak still have the same issue before it would start after a while that it would start everyday as long as you started it every day but if you let it set you play hell starting it looking for information on what could possibly be wrong maybe the CDI box not sure any help would greatly be appreciated thank you
