By Arizona
Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
too blury and cant tell wire color. Just too small. Thanks Az
By Peisledder
Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
By BillR94
Thank you for your time
Bill
By 95kingQuad
As the title says I am on the search for a used OEM 1995 King Quad Carb. I believe it says Mikuni on the side. If you could even help me find info on which carb it is exactly that would be helpful too, or motorcycles/other quads that use the same carb. Thanks!
By davefrombc
I added a pdf of the wiring of the various connectors used in vehicle socket and trailer plug wiring to the "Other ATV files" section in downloads.
