bahahahahahhahhaahhahahaha that's a good one...it did take some time, but have no fear, i made it out...without even crying too :) :)
anddddd since when did you start modeling? I was soo surprised when I found your picture this morning.....
    • By dvs1961
    • By autocustomizer76
      Hey all got a Kawasaki 300 that's seen better days I'm looking to get running.  But first, I'm working on a Honda 350 ES and mainly needing where are you all finding quality parts at good prices.  Atvs are really hot items around here right now and most of the folks wanting and needing them are not familiar with working on them.  I'm looking to find a good resource for information and if it works out well pass this group along to the folks I help to get them in the know how to get the most out of their machines.  Thanks in advance.
    • By blasirl
      I have inherited an ATV and I think it was purchased in  KY, but I am in WI.  Is there a way to do an online search using the VIN or what have you to try and find the last registered owner so that I might try to get the title?
    • By blasirl
      I have found a few useful posts and am looking for a way to bookmark them in the forum.   Is there a way to do this?
    • By 92BayouB
      Hey there all,
      First off thanks for the board. My Bayou 220 has survived 3 teenagers and is on its 4th now. Up until  recently it has been a virtual tank....until I decided to fix it;)
      Noticed some smoking from the engine block (not exhaust) so figured it was time for a quick top end rebuild. Now that I have it all back together, it fails to start. I've pulled the starter rope until my arm is tired.
      So I will be as detailed as possible and hopefully get some help.
      Completed:
      -New Head gasket
      -New Valve seals
      -New piston (standard)
      -New rings (standard)
      -All new seals
      -Cleaned up head and valves (didn't do any resurfacing, as it all cleaned up pretty easy)
      -All torqued to spec
      -Piston ring gaps all checked out
      -Valve clearances (Intake: .18mm, Exhaust .20mm). Not too tight, not too loose.
      Pros:
      -Engine IS making decent compression
      -DO have spark
      -Will fire for a split second if I drop some gas in the spark plug hole and pull start. Will NOT from carb and or intake valve.
      Timing:
      So I followed the guide of: TDC
      -Flywheel aligns on the “T” mark on the engine site hole
      -Cam gear mark aligned with the cover mark
      Seeing as this is my first time doing a top end rebuild on an ATV. Here are my questions and concerns:
      -I didn't realize (dummy me) that there are 2 TDC's. 1- Compression, 1-Exhaust.
      How do I know if I'm on the right one?
      -Does the cam need to be aligned a certain way when put back in? I just aligned the cam gear dimple with the cam and put it in. No alignment.
      Thanks ahead of time. I feel like I'm 90% there, but I'm missing an important step for completion.
