Hello,
I am new to four wheeling and just purchased a 1998 Honda fourtrax two wheel drive. It is in fairly good condition but has some parts missing. I am a little anal and want to have it look as close to new as possible.
I am looking for some rear fender parts specifically the right side black fender flair that has the plastic rivets that connects to the tan plastic fender and the frame support bar that ties to the fender. I also need both side foot protectors and the plastic cover over the kick starter (tan). I also need to replace the rear brake pads. Are there reputable on-line parts sources that are cheaper then the dealer? Is there anyplace on-line I can go to see how to change the rear pads.
It also bothers me that I do not have the original manual so I don't know things like; what type of motor oil to use and capacity and what other maintenance there is. I cannot find any grease zerks. Are there any? Is there a way to download a copy of the owners manual. What maintenance tends to get overlooked that I should check?
Does anyone have any advice for a first timer.
Dougs2002
Welcome to the site and the sport!. As far as taking care of your machine, wash it, change your oil and filter and keep a clean air filter.
Try this link for a manual.
ATV Manuals at Bikebandit.com | Category - Repair / Machine Make - Honda / Machine Year - 1998
And this link will shows you a diagram of every bolt and every washer plus everything else. You can order exactly what you need.
1998 Honda ATV Parts for TRX300 FOURTRAX, OEM and Aftermarket at BikeBandit.com
    • By HHurks
      Thank you!
    • By TomJulio
    • By gordonmacritchie
      all fuses are fine
    • By cruteg8
