  • 5 years later...
    • By motox88
    • By anthonyd256
    • By dvs1961
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
      I just got a 1998 Suzuki Quadrunner 250 I am restoring essentially. Post your pics of yours so I can reference anything in the rebuilding! Any pictures welcomed to include engine, wiring etc!!
