I am working on a 2005 Honda TRX450R.
I need to replace the lower and upper right front 'A' arms. And possibly the steering knuckle.
Will the 2006 'A' arms bolt up to the 2005 frame?
If not, what is the difference between 2005 and 2006 'A' arms?
Thanks.
OK, so after more research this is what I found.
The bottom arms are the same. The 06+ upper arms are longer than 04/05 uppers. If you want to use 06+ arms, then you have to use 06+ spindles.
I know a guy selling a whole setup for the front if you're interested.
    • By TomJulio
    • By gordonmacritchie
      all fuses are fine
    • By toe420
    • By toe420
