What: 2nd Annual "Halfway To Hazard" Charity Ride 2009
When: August 21st-23rd, 2009
Where: Abner Farm, Crockettsville Ky ----East Kentucky Trail System
Accomodations
Trail Ride Video Trailer
Halfway to Hazard Charity Ride 2009 Website
Bring your ATV/Dirt Bike or Side by Side.
Over $100,000 was raised at the 1st Trail Ride in 2008 for the Buckhorn Childrens Center and Family Services, lets do even more this year.
Halfway To Hazard Website
Click on 2008 Charity Ride Photos to enlarge
More Updates to come as event date gets closer !!!
THANK YOU for taking time to read this message :D
Halfway To Hazard puts on one awsome show!!!!!!!!! I highly recomend seeing them perform!!! The lead singer sang in my aunts wedding back in 91.
Would be one heck of a great trip!!!!!!!!!!!!!
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By Eisenmatt17803
      Good Morning!
      Thanks in advance.
      Trail System Deep Dive
      Final Thoughts
      Visit Pine Mountain ATV Park
    • By Zrach
      I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
      This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
      Note: This modification compromises the factory “no-start” circuits.
      On some malfunctioning CDI units the internally damaged circuitry is only partial.
      Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
      The Modification
      See the second diagram attached below for the wiring specifics.
      The Result:
      The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
      ⚠️ IMPORTANT SAFETY WARNING ⚠️
      Please be aware that this modification compromises the factory safety "no-start" circuits.
      The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
      Faulty CDI Workaround.pdf
    • By WeeBee
