By Sofaspud
By Uglyside38
Anyone have experience using Meier aftermarket plastics? OEM ones are shot on my quad I'm restoring and I have them "Frankenstein'd" for now...🤦🏼♂️😬
Just curious on opinions on Meier as that seems to be the only place I can find any type of replacements. (And they're pretty pricey!)
By p5200
Is it normal for the steering to be hard to turn on these. Or, is there something I should be checking on the front end components. also, do these come stock with grease fittings? Thanks!
By Sha35297
So I have used the service manual to troubleshoot every sensor on this bike. Everything tests good accept the EPS Control unit. However, I do not see anything in the manual that suggests that this will cause the issue that I am having. The bike will start instantly when the button is pressed sometimes and then other times it wants to turn over forever and make a horrible knocking sound. Sometimes backfiring. After cycling the ignition it will sometimes start up right away. I have triple checked the timing and also the valve clearances. Everything checks out. The bike is for a customer that really doesn't know anything about the bike. From what I can see, the cylinder appears to be new, along with the starter. I did a compression test and it is a little high (74psi) Book says 71.7 is max. I can't see this little bit causing the problem, but I could be wrong. Last thing is that the idle is a little high. I have tried everything to get it to slow down with no avail. When I put it in gear it will jump slightly and is hard to get back into neutral due to high RPM's. Any Ideas or suggestions will be greatly appreciated.
By gpenberthy
My ranger crew 700 is hard to shift and gets locked into forward. When trying to shift into reverse we have to shut engine off. Shift then restart. Checked linkage and gears are fine. The RPMs arent really that high but did notice a little improvement when we lowered it. Did notice the throttle cable looks damaged. Could this be the issue?
Similar Tagged Forum Content
