    • By wheeliewayne
      my  2012 big bear 400 is hard shifting  can anyone help me
    • By Sofaspud
    • By Uglyside38
      Anyone have experience using Meier aftermarket plastics? OEM ones are shot on my quad I'm restoring and I have them "Frankenstein'd" for now...🤦🏼‍♂️😬
      Just curious on opinions on Meier as that seems to be the only place I can find any type of replacements. (And they're pretty pricey!)
    • By p5200
      Is it normal for the steering to be hard to turn on these.  Or, is there something I should be checking on the front end components. also, do these come stock with grease fittings? Thanks!
    • By Sha35297
      So I have used the service manual to troubleshoot every sensor on this bike. Everything tests good accept the EPS Control unit. However, I do not see anything in the manual that suggests that this will cause the issue that I am having. The bike will start instantly when the button is pressed sometimes and then other times it wants to turn over forever and make a horrible knocking sound. Sometimes backfiring. After cycling the ignition it will sometimes start up right away. I have triple checked the timing and also the valve clearances. Everything checks out. The bike is for a customer that really doesn't know anything about the bike. From what I can see, the cylinder appears to be new, along with the starter. I did a compression test and it is a little high (74psi) Book says 71.7 is max. I can't see this little bit causing the problem, but I could be wrong. Last thing is that the idle is a little high. I have tried everything to get it to slow down with no avail. When I put it in gear it will jump slightly and is hard to get back into neutral due to high RPM's. Any Ideas or suggestions will be greatly appreciated.
