A few of my friends
    • By vlxerdon
      Don
    • By dvs1961
    • By davefrombc
      COVID, record heat wave,  fires,  floods, deep freeze and more fires. Good riddance 2021.  Have a Safe and very  HAPPY NEW YEAR everyone.  May 2022  make up  for the trials  of the last 2
