Reading, PA (9/17/2009) - Custom Axis Racing Shocks, a world leader in power sports suspension technology, is excited to announce the launch of their redesigned website, viewable at www.customaxisshocks.com.Product information such as shock features, current application charts, technical manuals, and suspension upgrades are easy to locate, as each section of the site is now customized by
More...
    • By DGBear
      This thing is stuck in reverse! 2021 Axis with less than 15 hours on it. I cranked it, let it idle for a few minutes and when I put it in reverse the engine died and it won't come out of reverse gear. Any help is appreciated.
      The AMA U.S. ATV Motocross Team of Bryce Ford, Joel Hetrick and Brandon Hoag dominated in the Czech Republic at the 2024 Federation Internationale de Motocyclisme (FIM) Quadcross of Nations. It marks the sixth time that the team has secured a global championship since 2017.View the full article
    • By JGou
      Have an axis 500 bought from Lowes.. Have had to adjust the shift linkage  1/2 doz times in the last year.. Now the UTV is stuck in neutral.. Seems to shift ok through gears but neutral light never changes, and wont move at all when running.
      Only have 13 miles on this 4x4 and have had no other problems... Any help would be greatly appreciated.. Thx,  Jay
    • By Shadowace
      I have a 2016 artic cat 700 tbx seems like the power steering is not working what some obvious things that I can check.tks.in advance.
    • By geezer99
      Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago.  This post will be about my impressions as I use, fix, and abuse the machine.  I will add to the post as I gain experience with it.
      Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections.  Zirks were all freshly greased, fluids in engine, and gear boxes were up to level.  One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
      The rear gearbox does not have a differential in it.  It is essentially a solid axle.  Tight turns on lawn will leave tracks, and turns are not as tight on pavement.  In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
      To check engine oil you need to remove both front seats and a plastic cover.  This according to the manual.  I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
      I am not used to a CVT transmission.  I am used to a clutch and multiple gears.  This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up.  I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
      The doors have bungie cords to act as springs to close them.  I removed the driver door so I would not need to fight the constant pressure to close.  Problem solved.  I will leave the passenger door as is.  Gotta keep the grandkids safe.
      Here is some stuff I like:
      I was concerned about there being enough torque to slowly climb a steep hill.  There is.  I will elaborate more on this when I've had it on my steeper trails.
      The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff.  This helps a beginner with feedback that an action taken was successful.
      The sparsity of knobs on the tires dig in well on most surfaces.  I bet they wear out fast on pavement.
      The tilt bed has a tail gate that is easy to operate.  Much like early Japan pickups.
      Steering is responsive and little slack.  Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
      Seats are pretty nice.  Will be interesting to see how long it will take me to poke a screw driver though them.
      Seat belts are included to hold grand kids in.  Won't go over 5 mph if both aren't buckled.  Yeah, it works to buckle them empty.  Doing this leaves the belt high on back, so you don't have to sit on it.
      Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV.  This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well.  Creeping over the one well required climbing a 10 inch vertical well.  The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well.  The guys at Lowes were impressed.  They won't touch any but an unobstructed flat trailer loading.
      tom
