By ATVNetwork
The 2025 ATV Motocross National Championship Series, an AMA National Championship, concluded this past weekend at Briarcliff MX in Nashport, Ohio. The season finale also hosted the third and final AMA Pro Triple Crown.View the full article
By DonB
Had fire start in muffler due to failing fuel pump &/or fuel pressure regulator. Must I spend the $750+ for a new assembly from Arctic Cat?!? Here's what I've tried so far.
Replaced fuel pump & regulator - both from Quantum. PSI is 60 rather than the 42 the dealer advises it should be, so problem persists. I've now twice replaced the Quantum regulator & discussed w/ Quantum. They advise that they don't have an alternative regulator that would bring PSI down to 42. I've tried several in-line, adjustable pressure regulators but they either didn't work or I couldn't get a constant pressure from them. FYI, I've only tried the adjustable regulators for Fuel Injected engines however, it seems that they require vacuum to function properly. When I can temporarily get the PSI right, everything works great. Anyone else ever dealt with this problem, and, if so how did you fix it? Perhaps I should adapt the fuel system to include a gas tank return line?
Any insights are greatly appreciated, Don
By ATVNetwork
The AMA U.S. ATV Motocross Team of Bryce Ford, Joel Hetrick and Brandon Hoag dominated in the Czech Republic at the 2024 Federation Internationale de Motocyclisme (FIM) Quadcross of Nations. It marks the sixth time that the team has secured a global championship since 2017.View the full article
By ATVNetwork
Budds Creek has been steadily developing a healthy following when it comes to the ATV Motocross series. Since returning to the series schedule, the accolades that seem to flow out of this venue continue to be positive and the vibe lived up to its feel again here in the 2024 season. View the full article
