Hello clubbers,greg king here wants to let you know that if you have polishing needs,i can help.
Currently doing a lot of polishing on atv's at this time,from rims to carbs,no job to big or to small,i do it all.with 22+years exp you know the job will be done rite!!very good prices!!
For more info you can check out this link Home there you will find all my work pics,info,and a guest book that you can sign and get discounts & deals!!!
It is winter and a lot of people are on the tear downs.
THANK YOU.........GREG KING @ GKINGPOLISHING.COM
    • By jimbo69
      my outlander 800 sometmes starts and does good ouker times starts but will not idle .any one else have same problem?
      How come i cant download manuals i was told this is a good spot to find one for my lt230s quadsport.
    • By tflack500tbx
      Background,
      Any Ideas?
    • By kevinohio
    • By Gtc4d
      Thanks.
      Todd
