By dropze13
Hi,
I am recently new to quads and want to learn about the basics and know what i need in case i buy one this coming winter, i am currently looking at quadzillas due to them being available where i live and when looking a better choice than a yamaha raptor as i have a couple friends who rebuilt the engines on them 2 or even 3 times and always had somekind of problem.
What do i need to look for when buying a quadzilla engine wise and what do i need to check before purchasing one. I heard the quadzillas are reliable and are not a bad quad overall and they do not look bad either.
Also what are typical problems with the engine and what do i need to regularly check / maintain to ensure i can ride with peace and not need to worry about anything breaking, how much do they also last in terms of miles and ride time ( i know this depends on the use, i will mostly be doing off road and some street use so around the 40-60 mark if they reach that )
And to service / maintain them what do i need before hand, what oil, what sparkplugs and anything else such as coolant for summer / winter use.
And if there is any aftermarket parts / components that i can invest in please let me know to explore my options.
Thank you very much and i appreciate the help which i may get and hope to get into the quad scene soon!
By Its-always-something
By p5200
By dvs1961
Just bought a new hisun ,been shopping for a year or more for a sxs best bang for the buck...Are there any lift kits out there for a 2022 Hisun 750 sector ? links thanks
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
