By quadcrazy
Pretty cool modification for all you 3-wheeler enthusiasts!
CboysTV - "In today’s video, we build an electric 3 wheeler out of an E-bike pro. We also take our sandrail mudding and later try and find the love of our friend Gavins life by taking him speed dating."
By Topendcol
Col
By Dezertrider65
I just have a question.
If I was to buy 3 Wheeler from a private party say a 1985 Honda 350 can I get it made street legal and if not can I still ride it out in the Arizona deserts?
By Mikael
I recently bought and old Kazuma Dingo 150cc and to begin with it started just fine. Then, for no apparent reason, it wouldn't start. It turns the motor but fuel isn't getting to the spark plug.
As mentioned in the title I've since replaced the fuel filter, the carburetor, the ignition coil and the spark plug. Fuel comes into the carburetor but seems to go no further. Is it a vacuum problem? Does anyone have a good idea about how I could diagnose the problem? And how to fix it?
I don't know what year it's from, sorry.
Sincerely
Mikael
By Threewheelerer
I just was given a 1986 trx250 utility version that has the whole front end cut off. I wanted to convert the fourwheeler into a three wheeler since there is no way of putting the front end back on. The conversion seems that it could be easily done besides the steering. The steering on the four wheeler has a Long steering stem area and the three wheeler a short one like a dirtbike. Is there any way of cutting the steering stem down or does anyone have any other ideas? Thanks!
