i just got another rear bearing carrier off ebay and before i put it on i need to find out how much to tighten the axle. Also, i just saw a pic on this site and the axle nuts are on the right side. Mine are on the left. Does it matter?
    • By BillR94
      Thank you for your time
      Bill
    • By BruinBeater
      Hey all, BruinBeater here.  Just joined up from the Pittsburgh, PA area.
      I'm the unofficial mechanic of the extended family.  In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage.  Both have a no start condition and have been sitting for 2+ years.
    • By middlebrookgt
    • By Matdum
      Is there a common trouble to have the connecting rod bearing failure on a 2006 330 polaris magnum ? I have one who have failed and i want to know if there is something to check specifically
      thanks a lot !
    • By shorty
