Hey guys I am new here. I have a big problem I have a 1986 yamaha ymf80 moto4 and the carb is shot. Is there any other carb (raptor 80 ect) that will fit so I don't have to spend $250.00 through yamaha..
The carbs for all of the Yamaha 80cc ATVs are strikingly similar all the way up to the Raptor 80. All models even use the exact same intake tube that connects the carb to the head. While there are some slight differences in the carbs over the years, they are enough alike to make me thing they could be interchangeable. That does not mean that some adaptations may need to be made though, as they aren't exactly alike, but close. I would recommend checking ebay, you may find a decent used carb that is an exact match, or parts to fix yours.
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
    • By KIWINZ
      Hello
      My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty.  He cleaned the carb and then with some either it started and still starts first pull.  Its runs really nice - not rattles etc.  Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
      1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine.  No crunching or missed gears - just no first gear.  2nd gears appears to be as low as it will go
      2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had.  Other is a Quadrunner which doesn't have this feature)
      3) no neutral light - will start when no in neutral - should it do that?
      4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
      5) checked the clutch adjust on the RHS - seemed fine to me.  When i turned the screw back 1/8 it was where it was to start with.  Clutch doesn't slip.  The bike will move forward is all gears.
      Any help would be appreciated
      Andrew
