hi
By BillR94
By BillR94
Thank you for your time
Bill
By WeeBee
By GERONAMO308
Hi all, does anyone know what type of plastic is used for making ATV fairings.
In particular Suzuki Quadrunner 1992, if i cannot get a plastic for it in Red for the rear i will attempt repair.
I have a King Chrome plastic welding kit, however you need to know what type of plastic you are welding.
Any advice would be greatly appreciated.
By wjmedic
right front hub again
