powdercoating?
By quadandy
Hey guys! Stoked to be here because ive found its pretty hard to get help for mini quads
I recently bought a mini quad (it's a piece of poop so i have no clue the make) and it ran perfectly fine. I was running it a few weeks ago all day and it worked fine and the next day when i went to start it, the kickstart bar was super hard to push down but i could still do it, then it would skip and finish off hard to push down.
I have fairly intermediate mechanic abilities so i was able to pull off the cover and start playing around. it seems the kickstart spring is fine but i noticed a bunch of metal shavings. long story short i posted pictures and took a video of how things are kind of running. i assume the gears started grinding and now they wont catch fully, hence the skipping?
Also, im aware the main gear on the left has broken teeth, i found out the hard way when i tried to take off the nut and the teeth broke.
IMG_7447.MOV IMG_7445.HEIC IMG_7446.HEIC
By Matv88
Bought it new for my son. Pretty unhappy. Very very very lean at idle. Then there were a few things the dealer should have done during assembly including choke cable adjustment and rear brake adjustment.
I'm going to drill out the tamper proof plug and adjust the idle/air screw to see if that helps.
