hey guys just joined up , looks pretty cool here lots of good info here , who do i need to talk to about spreading the word here about my powdercoating shop?
if you have any pics of your work you could post them to your profile page along with talking about your shop there. once you do that you could enjoy all of the wonderful things this site has to offer, be active, make friends and let people get to know you. show some support and you will get it back.
Welcome to the site and have a great New Year.
    • By paradiseestatesales
      Howdy, look forward to all knowledge available here
    • By Heymax
      I bought a 2003 Bombardier Quest XT 650
    • By quadandy
      Hey guys! Stoked to be here because ive found its pretty hard to get help for mini quads
      I recently bought a mini quad (it's a piece of poop so i have no clue the make) and it ran perfectly fine. I was running it a few weeks ago all day and it worked fine and the next day when i went to start it, the kickstart bar was super hard to push down but i could still do it, then it would skip and finish off hard to push down.
      I have fairly intermediate mechanic abilities so i was able to pull off the cover and start playing around. it seems the kickstart spring is fine but i noticed a bunch of metal shavings. long story short i posted pictures and took a video of how things are kind of running. i assume the gears started grinding and now they wont catch fully, hence the skipping?
      Also, im aware the main gear on the left has broken teeth, i found out the hard way when i tried to take off the nut and the teeth broke.
      IMG_7447.MOV IMG_7445.HEIC IMG_7446.HEIC
    • By theoutlaw
      Hi. Just joined. Looks like a cool forum to be on.
    • By Matv88
      Bought it new for my son.  Pretty unhappy.  Very very very lean at idle.  Then there were a few things the dealer should have done during assembly including choke cable adjustment and rear brake adjustment.
      I'm going to drill out the tamper proof plug and adjust the idle/air screw to see if that helps.
