My quadsport at just off idle runs like crap it back fires bogs sputters chugs and just sucks so bad that i cant ride it cause it anoyes the crap out of me. it starts fine then when it warms up it gets worse, sometimes if i ride it for a long time it will only run at like allmost half throttle any more or less it bogs and pops and has no tourqu. but when it first starts up it will bog untill a little below 1/5 it will bog then when u hit a certain point it runs fine. my pilot jet is 20 and my main is 112.5. please help, Thank you the plug is a blackish black but it smokes a lot.
Edited by rocky_mtn_honda
Added model year to thread title.
What year is your Quadsport?
Your problem could be one of many things, possibly a problem with the CDI, could be that your valves need to be adjusted, dirty air cleaner, leaky rings or valve guides. Besides it running poorly, the fact that it is smoking is the only real indicator of a problem that we have to go on, so what color is the smoke? A couple things you could do to try and isolate the problem are; a compression test, check the valve clearances and timing, check the timing key, check the fuel tank and carb for deposits or blockages, check your air cleaner, try installing a new spark plug.
    • By BillR94
      Thank you for your time
      Bill
    • By Banshee898
      2014 Honda Rancher TRX420TM1: Unit starts right up, once it warms up it stalls and more difficult to start but once it does start it won't stay running. I have replaced the fuel assembly, IACV, O2 sensor and fuel injector. There are no active DTC codes. Disconnecting fuel line at injector and turning on key there is a steady stream of fuel. Plug looks good did not see crack in ceramic. Is there any way to test the ignition coil?
      Thanks for any help.
    • By WyattLemke25
      Working on a 2016 Sportsman 570 and it has a new battery and spark plug. No codes, fuses all look good. It cranks for a while and when it starts it will only run for a few seconds before stalling. At one point it was running at 3000 rpm with no throttle input, then it dies. Not sure where to look besides messing with the throttle cable, so suggestions are appreciated, Thanks.
    • By Indiana-George
      I'm new to the mechanics of riding. I've ridden quads and love it, but I've never really owned one of my own. I bought this quad in pretty rough shape and have been slowly restoring it. I'm almost ready to kick it over, but I'm doing a little research before i add fluids. I'm wondering what kind of oil i should use. I know the specs call for 10w40, but with the age and brand of my quad I'm curious to hear an experienced opinion. And since I'm just getting started with this forum, I don't have access to the service manuals yet. Any and all advice is welcome and appreciated! Thanks and happy riding!
    • By Seriousbird
      Recently swapped a good top end with a bad drive output onto a engine with a bad top end but with a good drive output.
      Engine 1 (bad drive output), top end was perfect and always ran good for me.
      Engine 2 (good drive output), top end was toast but it has a output.
      I swapped engine 1's top end onto engine 2. Didn't take the rings off all i did was everything from the piston to the valve cover. Sleeve, cylinder, valve system, cam, whole top end. Now that engine 1 is on engine 2 it runs good. Doesn't burn any oil, SOMETIMES.. i went on a fairly decent ride without burning a drop of oil then at one point i noticed i was burning it like a steam train. Drove off a bit more and it was like nothing happened?? It all happened on flat land. Im not overfull on oil. Any suggestions? The rings were untouched and are in their original cylinder. They did come out of the cylinder at one point.
