By JohnnyB
Greetings,
By HSTAR
By ResQ91
Hi guys
battery and connections good
By N00bie
From Arkansas. Just bought a 2012 Gator 850i RSX because I could not pass up the price. BUT it has an idle problem. So, to be honest, I joined just to get a service manual. I have a choice: 1)Buy a hard copy: ~$100; 2)Buy a CD ~$35.00; Get a direct download for free posting 10 times; or get a download for $29.00 (subscription). Haven't decided what to do yet.
By McG75
Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds. It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
