By kawasig
By Atomusthenes
By DaleJAM
By Does_This_Look_Bent?
Hey everyone, I just replaced the carp on my 98 Kodiak 400 with PN#4SH-14101-00-00. It starts and idles perfect, but once it’s good and warmed up, it bogs out at 3/4 throttle or more… it sounds like it’s bouncing off a rev limiter haha… I tried the air fuel screw, all the way in and out 2-1/2, and it made it a touch better… tried 2 turns and no different. Am I missing something?
By Daleon
I recently was gifted a 1998 Lakota 300 and it was modified to start only by electric start. ( Removed the pull start) So I put together all the parts he was able to find and I believe it's back together like it's supposed to be but when I start it via electric start, it turns over but I do not hear the sound a proper combustion sound makes. Furthermore, I did all the spark tests and it's showing none whatsoever.
I installed a new starter and I believe I installed it correctly. Could I have accidentally thrown the timing off? I lined up the timing marks but the top mark will NOT line up correctly.
